Programmatically Turn off Orientation Indicator
974
07-15-2010 10:02 AM
MargoBlosser
Hello???I am after the same functionality  exposed in the AE Display tab that allows a user to turn off the Orientation Indicator by setting the position to off.
I have tried the following code:
ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.Settings.ShowNavigator = False
This only turns the navigation feature off.
The Navigator position enumeration only has a topleft and bottomleft enumeration. What I need is an off position for the following code:
Dim navpos As ESRI.ArcGISExplorer.Mapping.NavigatorPosition = NavigatorPosition.TopLeft
Any suggestions would be appreciated,
Margo
AndreiIvanov
Hi Margo,
try this:
ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.Settings.ShowNorthArrow = False;
