Need help with Arcgis Explorer Bugs
1841
07-14-2010 05:03 AM
NoureddineMaghmouli
I have installed AGX 1200 on six machines, it works very good in 3 machines which have Windows XP 2002 SP3 32bits, but for all machines which have 64bits system it did not work, i the first i thought the problem is only with 64bit but after that we tried it with another 32bit machine it also crashes,
what is happening is the application open normally but when we try to open the .nmf file which contains layers and Tif image it bugs and gives a serious application error(attache image),
please let me know if you have any suggestions or solution for this problem,
Regards
Noureddine
NoureddineMaghmouli
any help?
Noureddine
