Multiple Basemaps as Layers
1114
02-16-2012 11:20 AM
DavidSchultz
Hello,
Just started working with ArcGis Explorer and find it amazing.  But, I'm stuck with something that should seem easy but I'm somehow missing it.  I have read several posts about re-writing code, inserting code, etc., but don't even know where these people are adding this info...  Anyway, my problem...
I would like to have two BaseMaps (ie Imagery with Labels & Physical or Topo) combined.  So, the Imagery with Labels would be the BaseMap and then I could change the 'transparency' of the Topo Map to my fancy.
Again, I'm a noob to this program.  Please help.
Thanks for any help on this matter.
Dave
MarkBockenhauer
Dave,
You could add the layers from http://services.arcgisonline.com/arcgis/services and create your own basemaps exactly the way you want them.
http://webhelp.esri.com/arcgisexplorer/1700//en/add_gis_services.htm#
Once you have added the data, and have it looking the way you want, you can save it as a basemap.
http://webhelp.esri.com/arcgisexplorer/1700//en/command_save_as.htm#
Mark
