Line thickness of scale bar?
2896
08-05-2014 01:44 AM
SimonLaughton
Hi folks
I am trying to adjust the line thickness of a scale bar I have placed on my map document.  I can see how to change the base (horizontal) line thickness/weight but the small sub division lines I cannot see how to adjust the weight of.
Any ideas?!
Si
DavidBarnes
If you are using a scale line or other scale bar type with marks enabled:
in the Scale Bar properties, Numbers and Marks tab, click the Symbol... button next to Division Height and/or Subdivision Height to edit the symbol for the division and subdivision marks
If you are using one of the other scale bar types, without marks:
in the Scale Bar properties, Format tab, click the Symbol... button (or Symbol 2... button as needed) in the Bar section to edit the symbol outline
DavidBarnes
ZackK
Hello Simon,
As David said...  see attached images...
Scale line:
Scale bar:
Due to the nature of the forums and the points, please mark David's answer as correct, so he can get the credit for answering the question:)  Thank you.
DavidBarnes
Thanks for the screenshots, Zack! Very helpful.
ZackK
Np, I had couple of extra minutes before lunch:)
