Hyperlinks in ArcGIS Explorer
4097
05-21-2010 02:17 PM
srikanthmatta
Hello
I have created a feature class in a geodatabase. and for each feature I defined a hyperlink (eg. C:\xyz\abc.pdf).  It works fine in ArcMap. But when I add this to ArcGIS explorer the path is popping up as just a string.  Is there something I am missing for the path to show up as hyperlink?
Thanks
Srikanth
MarkBockenhauer
Srikanth,
You are not missing anything.  The popup window does not automatically show file paths as links. In the popup properties you could choose to "use the value of a field as popup content" to see the PDF file when you click the feature.
Keep in mind that anything you author that relies on a drive letter file path will only be useable on your computer, or another computer that duplicates the folder structure that you have on yours.
Mark
shanybenj
Mark,
How can I set the hyperlinks for a parcels map to open PDF documents when the user clicks the features in ArcGis explorer?
Shany
AdamRepsher
Mark,
Shany
I believe that you have to either begin your link with "file" as in:  "file:///C:/abc/xyz.pdf"
OR
Use the machine name: "\\yourmachinename\C$\abc\xyz.pdf"
That would also work for network shared drives -- so if your organization has a drive which everyone shares, you can store the document there and everyone could access it through ArcExplorer.
Thanks!
--Adam
EDIT:  I forgot one thing.  If you organize the documents into a clear filing structure, you can create a field in your parcels data and do a field calculation to get the link (in ArcMap).  In my situation, I have "sites" with a specific SiteID.  That attributes is in my point feature class.
Our shared drive would then contain a folder structure specifically for PDF documents related to those sites:  ...\SitePDF\[SiteID].pdf
So, if I had one PDF I wanted to show for each site and the name of the PDF was the SiteID, I would utilize the Field Calculator to populate my Links column.  The VB would read:
"\\myserverORmymachine\Drive$\SitePDF\" & [SiteID] & ".pdf"
...which would generate this:  \\myservername\Drive$\SitePDF\AD999.pdf
and would change for every Site in the Feature Class.
for example - the next one would be:  \\myservername\Drive$\SitePDF\AE001.pdf
Hope this helps!
--Adam
RalphTibiletti
Hello
Thanks
Srikanth
I have had that problem if I have "  " marks enclosing the path.  When I removed them it worked fine.
R.T.
