How to "suppress" Identify button when user clicks on map
950
02-02-2012 07:59 AM
MarilynGambone
I've just installed ArcGIS Explorer Desktop 1750.  I added an ArcGIS Layer to my map. The layer is created from a shapefile with multiple polygons. Each polygon has a numeric id (from 1 to 52).  I want to create a routine such that when a user clicks on a polygon, a form pops-up with specific data for that polygon.
How do I suppress the Identify button from popping-up and creating its own window? The identify button is also posting a wrong id; it numbers my polygons with zero-based index; my polygons' ids start at 1, not zero.
Any help is very much appreciated.  Thanks,
