how do I copy feature classes with attachments to another database
9724
6
01-09-2015 06:10 AM
CameronDodds
I have tried the copy paste method. It gives me an error (one or more objest failed to paste. FDO error: -2147483638). I am able to copy just the personal database feature class but it does not bring the related attachment table.
CameronDodds
More detail.  I have a Personal Geodatabase Feature Class, Table, and Relationship Class that I want to move to a File Geodatabase.
MarceloLandivar1
Have you tried to export to an XML workspace document and then import it?
If this does not work neither and you are on a hurry, you probably must (I think this could work but I haven´t tried it):
  • Create and update an auxiliary field in the pDGB attchments table to recreate the relations
  • Create just the schema in the fGDB
  • Load the data from pGDB to the fGDB. Use the Append geoprocessing tool.
  • Update foreign key in the fGDB attachments table to recreate the relations
  • Delete the auxiliary field
Hope it works!
Marcelo Landivar
Azimut Soluciones
CameronDodds
Marcelo,
Thanks for responding.
I tried the export XML workspace document and get the message "Export Failed."
Could you possibly give me step by step instructions for the other option to complete this task?
  • I was able to create the aux field in the PGDB.
  • Need instructions for the schema creation in FGDB
  • I know how to do the append
  • Need instruction how to update the foreign key in the FGDB attachments table to recreate the relations
  • I know how to delete the field.
CameronDodds
Thanks Sol,
I get the following error code when  export to XML Workspace.
Messages
Executing: ExportXMLWorkspaceDocument "C:\PSC AutoCAD Files\CARGILL\PSC.mdb\STORM_SEWER_MH" "C:\PSC AutoCAD Files\XML'S\STORM MANHOLES.xml" DATA BINARY METADATA
Start Time: Fri Jan 09 12:47:58 2015
Exported to C:\PSC AutoCAD Files\\XML'S\STORM MANHOLES.xml:
...STORM_SEWER_MH
...STORM_SEWER_MH__ATTACHREL
ERROR 999999: Error executing function.
Failed to execute (ExportXMLWorkspaceDocument).
Failed at Fri Jan 09 12:48:03 2015 (Elapsed Time: 4.87 seconds)
CameronDodds
Sol,
Thanks for your help. I believe you are correct. Something with that dataset. I am able to use the XML transfer with some of the other data with attachments. Thanks for getting me this far. I will review the data with the ones that get that error message. Thanks again.
CameronDodds
Sol,
The PGDB was not used for GPS data collection.
