Field calculator error 999999
1182
01-28-2013 01:18 AM
PeterCeelen
Arcmap 10.1
I have a vb script to creat a hyperlink in a new column.
In Arcmap 9.3 this script works perfect.
But in 10.1 i get a error.
Field [FOTO]  holds the values of a photonumber (example 105-2087).
Script Code:
dim naam as string
dim v as variant
naam = [FOTO]
if naam = "" or naam =  " " or  isempty(naam) then
  naam = ""
else
  v = split(naam,"/")
  naam = v(0)
  naam = "Fotos\Foto_2012\p"&replace(naam,"-" ,"")&".jpg"
end if
The result window gives error 999999.
Are there any surgesties the solve the error.
Or is there a new kind of script that i can use to get a photo numer from one column to an other with txt infront and behind
example: column photo input: 105-0285
column photo_hyp output: photo\1050285.jpg
thanks,
norie
You can try doing it in python:
In Codeblock:
import re
def toFileName(fname):
 output = re.sub(r'[^0-9]', '',fname)
 if output:
  return 'photo\\' + output + '.jpg'
 else:
  return ''
PHOTO_HYP=
toFileName(!FOTO!)
