Failed to execute (Select)
3678
04-14-2014 02:01 AM
DaphneBol
Hi!
I have a problem with my model. I have to run a model for 15 countries in Europe for calculating the best spots for implementing Hydro stations. For all countries it runs fine except for one. Every time I get the error: failed to execute (Select). The strange thing is that this Select tool works for all the other countries. Does anybody know what the limitations are for this tool (eg too large datasets, input/output location restrictions, extent restrictions, etc.)
Thanks in advance!
Gisbert61
In my limited experience 'failed to execute' was caused by errors in parameters. Does the country has something special like a name with a space? "new zealand" for example?
Can you test you script with only this country and troubleshoot from there?
