Failed to add shapefile: unknown failure
4418
01-07-2014 09:04 AM
TracyDash
Anyone know what this means? The shapefile works fine on three computers in my office but not on one. The coordinate system is good, all the files are there (.prj,.sbn,.sbx,.shp,.shx), and no issues on the other computers. I didn't see anyone else with this error online, just 'unknown coordinate system' but the coordinate system is fine...
Any help would be much appreciated!
JoshuaChisholm
Do you have your '.dbf'?
TracyDash
Yes, sorry I forgot to add that, I do have a .dbf.
JoshuaChisholm
Ok, then I'm not sure.
I can only think of one thing (if you're prone to the same kind of dumb mistakes as I am). It looks like your comp is hiding known extensions. Are you trying to add the "Project.shp.xml" file (which is appearing as "Project.shp")? It's a longshot, but thought I'd mention it just in case.
Alternatively, could the file have been corrupted? I hope you find a solution!
EllenBryson2
Hi Tracy
Did you install the Projection Expansion pack with your AGX install? That's an optional install, not part of the standard install. It might be that your prj file is fine, but it's some specialized projection that AGX can't work with without the Projection Expansion pack.
If you care to email me the shapefile, I will try to add it and see what my AGX does with it. [email protected]
