ARCGIS explorer 1500 browser capabilities
2037
6
04-26-2011 12:43 AM
kmirza
Can arcgis explorer be used through a browser of a client PC?? if yes can anybody help me do that??
any help/comment will be highly appreciated
Regards
khushboo
kmirza
requesting mentors of the group to please answer the query.
AndreiIvanov
what exactly are you asking for? Running in a browser (i.e. firefox, IE) - if so, no AGX does not do that. You could try ArcGIS Explorer Online instead. VPN, Citrix - it should be working.
kmirza
Thanks for the reply!!
yes, my ques was whether we can run arcgis explorer from a browser (firefox, IE)??
where main AGX application with data n all addins is kept on the server, and client doest not require to install AGX on his system.. whether this possibility exist??
also i came across this webpage http://services.arcgisonline.com/arcgisexplorer500/help/web_browser.htm,  whether this is applicable for AGX 1500 also??
Regards,
khushboo
AndreiIvanov
AGX1500 does not support this feature.
kmirza
OK..
Thanks aivanov for the quick reply
CameronWallace
Is it possible to host an instance ArcGIS Explorer Online (i.e. on an internal intranet?)? (I'm assuming you'd need to be running ArcGIS Server already...) or is this residing exlusively on ESRI servers for now? Are there any plans to release this in the future or on the cloud?
Cam
