AGX SDK: Control GPS Device from SDK
1139
06-17-2011 11:38 AM
CollinGrove2
Does anybody know if we can to control the GPS Device settings in build 1700 from custom buttons or extensions? I'm specifically looking to create a custom button that will enable/disable GPS tracking. Also looking to see how I can access saved tracks. Thanks!
-CG
AndreiIvanov
GPS is not part of SDK in 1700. SDK in 1700 remained the same as in 1500.
DanHuber
Andriy,  if the SDK has not changed, what is the SDK available on this page?
http://resources.arcgis.com/content/arcgis-explorer/1700/download
I noticed that if you tried to install the 1500 SDK on a machine that already had 1700 build installed, it failed saying that it could not find the required 1500 build.  Is this just an update to overcome that issue?
