AGX 1500 without transparency for image overlay
2678
09-28-2010 05:59 AM
DanielSchober
Hi all,
In AGX 1500 I am missing the tool to set a specific color of an image overlay to transparent.
It seems to have disappeared, see attached screenshot.
Thanks for your help.
Cheers,
Daniel
EdanCain
Daniel,
you can set it via the property page of the raster, or via the Appearance tab "Set Transparent Color"
Edan
AndreiIvanov
Daniel, this option was removed from 1500. As Edan said, you can still do it for Raster layer. We will investigate what's caused it. I will update.
AndreiIvanov
Daniel,
in the next release of ArcGIS Explorer this feature will be available again. Meantime, I've put together a simple add-in that does exactly what you are looking for:
http://www.arcgis.com/home/item.html?id=111545b636c640c7adbaf558aa380fcc
Hope it helps.
Thanks for identifying the issue!
DanielSchober
thanks for the information. Add-in works fine.
Thank you Andriy.
Cheers,
Daniel
