Widgets not working when changing map in Experience Builder template
1120
01-18-2024 03:29 AM
DSteff
Hello,
I'm trying to change the map in an an Experience Builder template that has pre-set widgets. If I change it, the screen either goes black or the map appears but the widgets all disappear.
Anyone know what is going on?
ShengdiZhang
Hi @DSteff ,
Can you provide more information about this error, such as which template you are using?
Regards,
Shengdi
DSteff
Hi, its a template my coworker in my organization put together. It works with other webmaps, but for some reason it has this issue with mine. It  does says that the widgets are still related to the map, but I cannot see them.
Sometimes I get the error message across the screen that says s.getCurrentQueryParams is not a function.
TonghuiMing
@DSteff
We're not sure about your environment, but here is a similar post that you may find useful:
https://community.esri.com/t5/arcgis-experience-builder-questions/getting-javascript-error-quot-s/m-...
