Why is zoom level in Experience Builder different from web map?
490
04-17-2026 05:08 AM
Bud
Legendary Contributor
In my web map, the scale is roughly 1:50,000 (best guess). An experience builder app that uses the web map appears to be automatically zoomed out at roughly 1:75,000.
Why is the zoom level in Experience Builder different from the web map?
Related idea: Honor web map scale/zoom in Experience Builder
JonM32
@Bud
I've noticed this too! It's annoying at times. For example, if you set up layers in a web map with labels, and set the visibility scales for multiple label classes, when you view the map in ExBuilder they don't draw how you set them up in the map.
You're spot on though, the scales do not line up, and it affects how everything draws between the two (map vs app).
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
DarinaTchountcheva
@Bud
Have you tried using the "Preserve Map Scale" setting on the web map?
