webpage unresponsive when filter records by extent is enabled
1260
11-18-2024 01:39 PM
Goldendelicious
I have discovered that setting up my attribute table to filter records based on map extent causes my page to hang and eventually result in a "page not responding" error. I'm not sure when this started but I know it wasn't always an issue. It broke several of my existing Experience apps and I've had to recreate them from scratch since edit mode hangs immediately upon loading. While not a critical function, it is a nice touch that I like having in certain apps.
It happens in all browsers I've tried: FF, Edge, Chrome. clearing cache doesn't help.
I am using Enterprise Portal 11.1, which I realize is not the most up to date and perhaps this problem has been fixed in a later version.
Does anyone have an experience with this, or know if its resolved in a later Enterprise release?
Is there a better work around other than just not enabling filter records by map extent?
Shen_Zhang
Hi @Goldendelicious, thanks for reporting! This is a known bug and it has been fixed in 11.2. Currently, there's no walkaround for this issue at the moment. Thank you!
Shen Zhang
Shen_Zhang
Shen Zhang
KimAllan
Could the same bug be causing the issue we are experiencing with 11.1. The tables are set to filter with the map extent but it has stopped working?
