Web Experience Builder - Dynamic Text Expression - Selected Features
2877
09-13-2024 07:56 AM
ChristopherMask
I believe I am correct in the assumption that arcade is not yet available for dynamic text?
If so, I could use another set of eyes on a dynamic text complication, which I will attempt to explain. I am using dynamic text for selected parcel count and acreage. The dynamic text calculates if a polygon feature is selected. I have three views on the parcel feature class, which are federal, state, and private views. The 3 only calculate acres and percent if all 3 views contain a selected feature. The TOTAL ACRES always calculates because it is the feature class and not a view. It would be good to write an arcade function to calculate the 3 if nothing is selected, but I believe this is out of the question at the moment.
Am I missing the mark here or does anyone have an idea to make the top 3 views (federal, state, private) calculate if only one view is selected?
Christopher
ODWC_GIS
I am right now sitting in a class for ExB, and was just told that Arcade does not work in ExB- with the single exception that Arcade can be used in the PopUps of WebMaps that have been brought into ExB.
ShengdiZhang
Hi @ChristopherMask ,
The text widget supports Arcade expressions in the June 2025 AGOL release. Please let me know if that solves your issue.
Shengdi
GoviPaulHines
Hi @ShengdiZhang, does this mean that it won't be available in Enterprise until version 12?
Govi
