Utility Network Trace widget result in multiple map
3141
6
04-29-2024 02:15 AM
April_J
Hello,
I have created an experience builder that contain two maps. One is Utility network map, and the other is 3D Scene. I want to show trace result in both maps so, I try to use add action to UN map, but it's not work.
The trace result from Utility Network Trace widget only shows on UN map and not select data record as action setting. But when I directly select features from UN map the 3D scene have selected features as action setting.
Do you have any suggestion if I want to show trace result in both of maps?
AlixVezina
@April_J Thanks for posting.
Are your two maps within the same Map widget or in two different Map widgets?
You'll notice that the trace results get cleared when you switch between the maps found within the same Map widget. That's a known limitation.
If you web map and your web scene are added to two separate Map widgets and you setup message actions for record selection changes between the Trace widget and the layer in your Map widgets, the selection results should be reflected as expected.
April_J
I use two separate Map widgets and setup action record selection changes between UN map and Scene in Map widgets. I notice that my Utility Network Trace widget doesn't have Action tab and trace result was as shown in the attached picture.
I use ArcGIS Enterprise 11.1.
Thanks for your response.
AlixVezina
@April_J The Action button for the Utility Network Trace widget was added at a later release. You'll find them in the current release of  ArcGIS Online and in Enterprise 11.3 (once released in May). You can also use the developer edition of Experience Builder to leverage the latest functionality.
April_J
@AlixVezina Thanks for information.
I'll keep the developer edition as a choice. Could you please recommend other widgets that can be used for showing trace results on the other map (not including UN) without using the Action from UN trace widget?
AlixVezina
I'm sorry @April_J , I can't seem to think of any other workaround at 11.1.
April_J
That's okay. Thanks for your help!
