List Widget and Map Widget not interacting correctly
631
05-01-2024 03:43 PM
SRP53
list widget is reverting back to original sort after selection in map is made...
I have a list that also has an anchored window. The list can be filtered by an outside filter widget.
When you click on an item in the list, the map will pan and zoom to the selected item from the list. It will also open the anchored window with more detail.
The map also allows you to click on a point and that point will be selected in the list, in which the anchored window should also open.
2 issues:
  1. When you select the point and it highlights in the list the anchored window does not automatically open. Is this even possible?
  2. The MAIN ISSUE or BUG, once the point is selected in the map and the list filters to that selection, if you go to the list to click on the selection and open the anchored window it no longer recognizes that it is selected and reverts back to the originally sorted data. So no matter what it opens the wrong item.
