Using list widget to turn on/off imagery layers in a web map
1551
08-24-2022 12:57 PM
HenryEmilie
I'm trying to use Experience Builder to create a tool that will be used by planners to determine suitability of installing new septic systems across our watershed. The web map I'm using contains multiple imagery layers that are hosted on our image server. I'd like to find a way to use the List widget to turn on/off different imagery layers that are displayed within the web map. For example, when someone clicks an item in the list, only that image is displayed on the map. I've found a way to do this with web maps that contain feature layers but not imagery layers. Is this possible?
jonathanharte
Hi,   I cannot help ..   but I'm trying to do the same thing with Feature Layers and Imagery layers - so hopefully somebody responds..   can you outline how you have done this for the feature layers please ?
Thanks
Paulg
by Anonymous User
Not applicable
See above reply
by Anonymous User
Not applicable
Hi Henry, we created an Oriented Imagery mulit catalog viewer widget you can check out but I am not sure if you are using Oriented Imagery. Let me know if we can help!
https://www.esri.com/en-us/arcgis-marketplace/listing/products/f43fde9781504341b680f35b5dcfb25a
Heres an example of what it looks like and how to use it.
https://www.youtube.com/watch?v=DlCaItuRMp8
CharleneSylvester
In my limited experience to date, support for imagery layers appears to be lacking. If I bring a web map into my ExB site that has an imagery layer, it will display via the map widget, but that's about it. The filer widget doesn't see it, nor does the timeslider widget.
I really hope there will be more support for imagery layers in future ExB releases.
