Using Arcade with Cards
1512
07-20-2020 06:19 AM
erica_poisson
I am attempting to build my first Experience and I am running into some issues using the Arcade expression I want within a Card widget. I'd like to show a count of events within the past 30 days, however I am unable to copy/paste my expression into the "Expression" section of the Dynamic Content dialog. I don't really even see a way to build it dynamically within the "Expression" section because the functions available are limited to AVG, SUM, COUNT, MIN and MAX.
I was really hoping for a similar experience to using the Indicator Widget in ArcGIS Dashboards, but so far I am struggling.
Is it possible to use functions like IIF and DateDiff and Now within Cards?
Any help would be appreciated.
Erica
Erica
berniejconnors
Erica - I beleive I am having the same problem as you.  I don't see how I can use or create an Arcade expression within Experience Builder.  Did you find a solution?
CherieBryant
I'm still running into this problem. Very odd that Experience Builder still doesn't yet support Arcade, unless I'm overlooking it somehow. It severely limits the applicability of the platform.
