Using a survey with geotrace with survey widget
321
06-14-2025 11:47 AM
kimkjohnson
I have a survey123 survey with a line geotrace. When i put it in the survey widget in experience builder there is no geotrace option, just the vertex option. Is it possible to do?
Thank you
Kim
Ruth_JiatengXu
Hi @kimkjohnson ,
The survey added to the Experience Builder survey widget still follows the survey settings. If you need the vertex option, you may need to republish your survey with the vertex option selected.
Ruth
