Use a view in a framework action
1424
01-02-2025 09:48 AM
AnthonyJonesRSK
Under the Add actions to widgets help section it states that "For framework actions, if the action data is the default view, the action affects all widgets using the data and its views. If the action data is a specified view, the action only affects the widgets using that view."
Not sure if I'm missing something here but how do you use a view as the action data? Firstly, I'm assuming it's referring to views created within the experience builder app rather than views generated in AGOL as separate layers. As you can see below my layer has a view called Data view 1 but this is not available to select when selecting your action data. Is there any way to set actions against views as the help suggests? This would be very useful to me as the alternative is to have separate views in AGOL or in my map which just makes things slightly trickier to work with across multiple widgets.
Thanks
Anthony
Ke_Xu
by Esri Regular Contributor
Hi @AnthonyJonesRSK
You could select views of Action data here.
Ke
Ke_Xu
Hi @AnthonyJonesRSK
Ke
AnthonyJonesRSK
Thanks for the quick response on this Ke, I'm obviously not up to speed after the Christmas break as completely missed that! Thanks for your help. Anthony
