URL Parameter : token
11205
20
04-28-2021 08:08 AM
GuillaumeArnaud
Hi
I want to use an app generate by ExperienceBuilder in an iframe where user is auth. I try to add a "token" URL Parameter to get an automatic login to a non public app (with non public webmap). With a webappbuilder app I write <appurl>?token=<token>. This syntax doesn't work with experience builder.
Is there a mean to do that ?
thanks
Guillaume
TonghuiMing
The sso REST endpoint supports it, so this could work:
https://www.arcgis.com/sharing/rest/oauth2/authorize/sso?redirect_uri=https://experience.arcgis.com/experience/{appID}&client_id=experienceBuilder&canHandleCrossOrgSignin=true&token=xxx
AlessioDiLorenzo
Is it valid for operations dashboard also?
BethLott
Can you confirm that the SSO REST endpoint with the experience.arcgis.com URL works, vs "could work"? We have a similar requirement for an application that cannot be public.
TomPattison1
Anyone get this working?  Really need a solution here.
TomPattison1
Doesn't this still require credentials login for ArcGIS Online?  Need way to handle credentials behine the scene like we could with Web Application Builder.  What is Esri's response to this?
AlessioDiLorenzo
Not working. It redirects to the arcgis online login page.
The idea is granting the access to a secured resource (an experience, for example) behind the scene to users that are not registered to arcgis online, through the token.
lah
Also desperate for a solution to this - this is a major limitation. ESRI support has also not been able to provide any suggestions, outside of making the app and data public (obviously not a viable option).
I've also looked into Dashboards and Instant Apps - neither of them are able to do this either. I'm really trying, but it's impossible to move away from WAB at this point.
DavidHerries1
Any updates on this, also need the same use case to allow a token to be used.
DaniIsenegger
Same for us. In order to migrate from WAB app to ExB, the possibility to authenticate using a token is mandatory
MadelineYoung
Any update on this- we are experiencing the same issues as everyone else in this thread.
