Urgent! Business Analyst blank, Experience Builder
2842
6
11-14-2023 09:47 PM
Labels (2)
Hanoit
Something happened with the Business Analyst widget when I deploy it. When I'm looking from the preview option looks great.
But when I save the project, extract the files and copy to my wwwroot folder just remain in blank
It was working fine until around 1 - 2 weeks ago.
Thanks.
FasilTiru
Hi @Hanoit
Please follow these instructions to download and deploy the patch for the latest version that fixes the loading issue.
A Business Analyst widget patch is available for Experience Builder Developer Edition (Version 1.13)
The workflow mode should load now if deployed properly to your web server as follows:
Fasil T.
Hanoit
Still having the issue...
FasilTiru
Hello @Hanoit,
Is your developer edition of ExB app pointing to portal (Enterprise) or ArcGIS Online? If portal, please make sure the geoenrichment service is configured properly as documented in https://developers.arcgis.com/experience-builder/guide/business-analyst-infographic-widget/
If this was working fine few weeks ago, I suspect something might have changed with your geoenrichment configuration or permission.
I also recommend that you download and deploy the latest version of ExB that was released last week here: https://developers.arcgis.com/experience-builder/guide/install-guide/
In addition, you will need to download the Business Analyst patch with this version from here: https://github.com/Esri/arcgis-experience-builder-sdk-resources/tree/master/patches/1.13/patch1/arcg...
I hope this helps,
Fasil T.
Hanoit
Hi @FasilTiru, thank you for your reply. Our app is pointing to AGOL. I already try with the last release and didn’t work.
FasilTiru
Sorry about that @Hanoit We are looking into this as we are able to reproduce the issue with the latest release. However, I tested the previous developer edition that you showed above in your screen shot and confirmed the app loads fine when deployed:
So I suspect there must be something else you might be missing in your deployment. Can you please confirm that you followed these steps to deploy your app? https://developers.arcgis.com/experience-builder/guide/deployment-topics/
Fasil T.
FasilTiru
Hi @Hanoit
Fasil T.
Hanoit
Thanks, It's working now.
