I'm working with Experience Builder developer edition and have two list widgets Widget one has states and widget two has counties. Both lists data are derived from corresponding map layers. If I select a state is List #1, I'm trying to filter the available entries in List #2. I have the action setup to filter the map layers, which works just fine, but the values in List #2 never change. It continues to show the complete county list for the nation.
In Dashboards you can wire it up to update other components, but I seem to be missing the obvious in EB.
Thanks in advance.
Hi @PaulNRWA .
For your case, the filter action should be set on the framework, not the map widget.
Regards,
Shengdi
Hi @PaulNRWA .
Regards,
Shengdi
Thanks Shengdi. That indeed was the solution.
