Update Lable
226
06-24-2024 03:40 AM
Labels (2)
CS_IBM
Greetings
I am using Experince Builder without Custom Widgets.
I cannot see how to edit/update the Label value from 1 to Area 1.
I must be missing something as I cannot see an option to update the Labels??
Any assistance would be appreciated.
AndreasHall
If you are talking about labels in a map they are set in the map, not in Experience Builder. Open the map in Map Viewer, edit the labels, and save your map. Then the changes should be reflected in Experience Builder.
CS_IBM
Hi Andreas,
Thanks for your input.
I cannot update the base Feature.
When I open the Map in AGOL, there is no option to update the Label field?
CS_IBM
Greetings,
I finally managed to get the Expression Editor to pop-up, so that I could edit the Label.
