Unable to scroll through accordion on mobile (Edit: Known Bug)
740
10-09-2025 09:12 AM
NicoleJohnson
MVP
Edit: BUG-000178890 for ArcGIS Experience Builder
I'm testing an experience in which I've used the accordion widget pretty heavily. Basically, I have one accordion "pane" per content area (map, charts, table, etc.), plus inside of those I sometimes have another accordion widget for accessing functions like filtering the map, viewing the legend, etc.
I thought this was going well until I decided to test the experience on my Pixel 8a. I can't seem to scroll unless I use the area around the main accordion. If I drag my finger from "Choose a layer" down to "View the legend" for example, nothing happens. If I tap to open one of those panes, then I can scroll through that one pane, but otherwise I'm stuck. I don't see this behavior when emulating a mobile device in my web browser.
What I've tried so far:
  • I do have this experience embedded within another experience, so I thought maybe that was to blame somehow, but opening the experience directly doesn't resolve the issue either.
  • I thought maybe putting the whole main accordion into a column of auto length might help somehow, but that's not the case either.
Is this a bug? Has anyone used the accordion widget to good effect on mobile?
NicoleJohnson
MVP
Marking this as solved, I was mildly panicked yesterday and forgot to check the bug repository!
NicoleJohnson
MVP
