Unable to embed published Web Experience into a map series story map
1963
02-24-2021 03:51 PM
QianLei
Hi, I created and published a web experience with Experience Builder and would like to embed it into a storymap with map series template. I copied and pasted its url into the web page link, but got the error of "the page you are looking for can't be found".
I tried to embed this experience into a basic storymap and it worked. Anyone has a clue what the problem is and or any suggestions how to work around? Thank you!
QianLei
Hi David,
Thanks for the reply. Actually I figured it out a couple of days ago. The experience is only shared with a group and I was using the long url for embedding in the map series, so it didn't work. After I used to short url, it worked.
Qian
DavidMartinez
Is this the template you're trying to use https://www.arcgis.com/apps/MapSeries/index.html?appid=6aab740eb5f146d0bbc073185aa726cb  ? If yes, I haven't encountered any errors with using an experience. Can you share your experience? It is private? What errors are in the console?
David
QianLei
Hi David,
Qian
