Unable to 'add to map' GeoJSON files via Add Data widget
2058
7
06-26-2023 08:08 PM
Hels77
Hi, we are no longer able to view our GeoJSON files which we have added via the Add Data widget in our EB app.  The file seems to upload fine but doesn't add to map and is not visible in the table either. This process has worked fine for us for 3 months previously.
I have added a new Add Data widget to test the process, same result.
KML and CSV files work fine.
TianWen
Hi @Hels77 , we've made the necessary adjustments to address the problem. Could you please verify if the issue has been resolved on your end?
TianWen
Thanks for the post. Is it possible to provide sample data so we can investigate the problem?
Hels77
TianWen
Compress it to a zip file, then you'll be able to upload it.
Hels77
thanks
TianWen
Hels77
Thank you Tian, working fine now
Hels77
Although previously added data is still not working, only working for newly added files.
