Token or Proxy for Experience Builder?
7372
10
10-25-2023 12:32 AM
Gordon_Aberdeen
Previously, using WAB, I was able to modify the config.json to "useProxy" to auto-login to the application.
Is there way to either: (1) Use Proxy, or (2) Pass Token as URL parameter?
Or another way to log into the Experience Builder without having to drop the permissions?
I am using a secure page, so I would like to share the ExB like I do with the WAB.
GertConradie
See if you have the postinit method for example, then start to work from there and add the codes that is needed.
The text "addProxyRule" is not in the file by default.
