Toggle NearMe Proximity Circle On and Off
1160
07-02-2024 08:24 AM
GregReinecke
Hello,
I have been using the NearMe widget and it works great.  Once the distance is set and the zone produced I'd like to be able to simply toggle the shaded circle on and off.  Is there a way? I thought perhaps a custom toggle button but I don't what layer or id or whatever the proximity circle feature is stored as.  Perhaps someone has an innovative idea.
Thanks.
GRMapper
JeffreyThompson2
MVP Frequent Contributor
There isn't a built-in way for the user to toggle the search area. Nor is there a way for the designer to completely turn-off the circle. The closest option I have found is to set your Sketch Color to transparent white. You'll need to go to custom colors and set it to 255,255,255,0.
Going into custom development options, you should be able to find the id of the graphic by console logging allLayerViews. I am pretty sure that it will be project specific, if not completely random.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-View.html#allLayerViews
This reactiveUtils example will probably be useful.
// Watching for changes within a Collection
reactiveUtils.watch(
 () => view.map.allLayers.length,
   console.log(`Layer collection length changed: ${view.map.allLayers.length}`);
https://developers.arcgis.com/javascript/latest/api-reference/esri-core-reactiveUtils.html#watch
GIS Developer
City of Arlington, Texas
GregReinecke
Jeffrey,
Thank you for the reply. Tweaking the sketch color doesn't really work for me in this requirement and I'll need to really understand the coding the opportunities you linked.  I though perhaps using the Swipe widget must provide an option so I'll continue to investigate that as well.  Thanks again,
Greg
