Timeline widget - No added data can be used. Using Living Atlas Ocean Layers
5081
6
01-31-2023 09:54 AM
kmsmikrud
Hello,
I was trying to add the Timeline widget to an EXB app and when I select the web map I get a message, "No added data can be used. Please add data."
Layers in the map include a number of time-enabled layers from the Living Atlas such as Sea Surface Temperature which currently works in an WAB with the time-slider. There are few other Living Atlas layers that are imagery layers from Esri.
Are these not supported yet in EB?
Kathy
TonghuiMing
@kmsmikrud I tried to search a living atlas layer with the keyword 'Sea Surface Temperature', and it does work:
Not sure what happened in your case. Care to share the problematic data here? Thanks.
kmsmikrud
Hi TonghuiMing,
thanks for taking the time to test out. I'm wondering I notice above that the Living Atlas data is feature layer instead of imagery layer, would that make a difference?
I've attached a screenshot of the data I was trying to use.
Kathy
TonghuiMing
@kmsmikrud Hi Kathy - The Timeline widget only supports three types of data:
The data source can be a web map, one or multiple map services, or one or multiple feature layers.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/timeline-widget.htm#ESRI_SECTI...
kmsmikrud
Thanks @TonghuiMing,
Currently the imagery layer works in WAB with the time-slider widget so is it on purpose that it won't work in the timeline widget in Experience Builder?
The data is temporal and time-enabled. Hopefully I am missing something but I'm using WAB as a work around.
TonghuiMing
@kmsmikrud It is more of a framework-level issue than widget controlling matter since Experience Builder has not yet supported image service layers as one of the supported data source types. There are a few similar requests on that and feel free to follow up on them:
https://community.esri.com/t5/arcgis-experience-builder-ideas/enhance-filter-widget-to-recognise-mos...
https://community.esri.com/t5/arcgis-experience-builder-questions/is-there-a-time-slider-widget-for-...
ENH-000143692
ENH-000153737
Laura
by MVP Regular Contributor
I am also getting this error, but on a web map and feature layer. They come from a collaboration.. is that a problem?
