Text box inside Card widget with Arcade code to count records
951
11-05-2025 06:24 AM
JoseSanchez
Good morning,
I’m looking for a sample that demonstrates how to use Arcade to count records from a hosted feature layer, specifically when connected through Dynamic Content in a text widget. I’m trying to understand how to access the data source and its fields using Arcade.
Essentially, I want to achieve the equivalent of COUNT("OBJECTID") in Arcade.
Ke_Xu
by Esri Regular Contributor
SanchezNuñez
Good afternoon  @Ke_Xu
I am looking for a way to implement this code from your link:
var ds = $dataSources["dataSource_id"].layer;
var distincItem = Distinct(ds, 'CNTRY_NAME'); return Count(distincItem);
Could you please explain to me how to add this line  "var ds = $dataSources["dataSource_id"].layer;" from the default function generated in Experience Builder;? How do I find the dataSource_Id?
function getFilteredFeatureSet(ds)
I do not understand how to  type this line $dataSources["dataSource_id"].layer;  in the function generated by Experience Builder.
// Documentation: https://arcg.is/18ejKn3
function getFilteredFeatureSet(ds) {
  var result = ds.layer;
  var queryParams = ds.queryParams;
  if (!IsEmpty(queryParams.where)) {
    result = Filter(result, queryParams.where);
  if (!IsEmpty(queryParams.geometry)) {
    result = Intersects(result, queryParams.geometry);
  return result;
Thanks
SanchezNuñez
Found it!
There's no need to declare a function—just typing the code is enough.
var ds = $dataSources["dataSource_3-1-dataView_1"].layer;
 var distincItem = Distinct(ds, 'OBJECTID');
