Table widget message action Zoom to and select feature on map that is in a layer that is not visible
2048
11-09-2023 01:30 PM
Jamie_Leitch_CNF
In EB with the table widget, if a user selects a record and there is a message action set up to select and zoom to the corresponding record on the map, but the layer is turned off, is there a way to force the layer to turn on, or perhaps flash the feature?
ShengdiZhang
Hi @Jamie_Leitch_CNF ,
You can try the action Record Selection Changes - Map - Flash.
Let me know if that helps or if you have any other questions.
Regards,
Shengdi
ShengdiZhang
Regards,
Shengdi
Jamie_Leitch_CNF
@ShengdiZhang Thanks, flash works.  Is there a way to turn the layer on if it is off?
ShengdiZhang
Unfortunately, there is no way to turn the layer on for now.
