In EB with the table widget, if a user selects a record and there is a message action set up to select and zoom to the corresponding record on the map, but the layer is turned off, is there a way to force the layer to turn on, or perhaps flash the feature?
Solved! Go to Solution.
Hi @Jamie_Leitch_CNF ,
You can try the action Record Selection Changes - Map - Flash.
Let me know if that helps or if you have any other questions.
Regards,
Shengdi
Regards,
Shengdi
@ShengdiZhang Thanks, flash works. Is there a way to turn the layer on if it is off?
Unfortunately, there is no way to turn the layer on for now.
