Table Widget -- Data Action -- Export Data
1435
06-26-2025 12:12 PM
D_Atkins
Maybe related to the latest AGOL updates, maybe related to changes in our licensing..
We had several Experience apps with Tables configured with the Export Data Action.  Today, the Export option seems to be missing from the Table Widget for users/viewers (despite double-checking sharing settings top-to-bottom).
Question: has anybody else noticed anything similar?
KathrynWalker
Hi @D_Atkins and @Matt-Huser,
The following bug was recently logged for similar behavior with secured Enterprise services:
  • BUG-000177589: Following the ArcGIS Online June 2025, the Export option is no longer available for secured Enterprise services in ArcGIS Experience Builder web apps
If you would like to follow along with the status of the bug, please reach out to Esri Technical Support and request that your case be attached to this bug.
Thank you,
Katie
Matt-Huser
Yes, we are experiencing the same issue with layers coming from an ArcGIS Server REST endpoint.  Looks like Hosted Feature Layers export just fine however.
Is this the same situation you have @D_Atkins?  Also have you started a support ticket that I can reference when starting our own bug report?
DougBrowning
MVP Esteemed Contributor
AGOL had major issues today after the update but should be back now.  https://status.arcgis.com/
KathrynWalker
Thank you,
Katie
BrittanyBurson
Just a comment that we are having this issue with NON secured services as well.
