Survey123-widget
978
08-12-2025 02:36 AM
Tage
by Esri Contributor
Hi I dont know if this is just Experience Builder/Survey-widget or Just a Survey123 question.
But I have created a survey with the widget in my Exp Builder, and in my survey I have a dropdown with "other" as an alt. But on the page the input field is no set to disable, and I dont know why?
ZenMasterZeke
What do you mean by 'set to disable'?
Tage
by Esri Contributor
Sorry, when I try to fill in my Survey, the text field on the "Other" alternative in my dropdown have a disable on it in the HTML. So It makes it impossible to add your own text. I cant see anywhere you can do that manually in settings or on other places.
ZenMasterZeke
For Survey123, are you using the web designer or Connect? If Connect, are you adding an 'Other' option to your choice list and displaying a text box for the user to enter data, or using the or_other keyword in the type column?
I rarely use the web designer, so not sure about that one.
Tage
by Esri Contributor
Im using the web designer mode. Thanks anyway.
