Survey not reloading in Experience Builder
1307
09-13-2022 02:18 AM
Lodry
Hello,
I created an Experience Builder app on ArcGIS Online in 2021 that uses a survey widget.
When I click on the map, some questions are automatically filled in the survey. The survey is quite complex and was developped with Survey123 Connect.
When the user clicks on 'submit', I want a new survey to load automatically. However, since mid-2022, a new option has been added to Survey to give the option of whether or not to refresh the survey after the user clicks 'submit'. The standard behaviour has also been modified from ‘auto-reload’ to 'no auto-reload'...
I've seen that we can set this auto-refresh behavior in surveys created on the web:
But is there a way to edit this behaviour in Survey123 Connect ?
Thank you,
Laurent
Richard_Purkis
Hi @Lodry This is setting is still possible to configure for surveys published from Connect. Just access the Design Tab via the same manner via  https://survey123.arcgis.com for your survey published for Connect. Less options will be visible but the Thank You Screen is accessible.
Let me know if this help
Thanks
