Sort in List Widget is not properly sorting by Date
2320
08-23-2023 12:08 PM
KaraUtter2
Experience Builder in ArcGIS Online, not enterprise.
When I choose to sort my List Widget by the Date Field, which is properly defined as a Date field in the schema, it is actually sorting by the month number instead of date. And for some reason the record without a date is up there at the top instead of bottom, as well.  See Screenshot below, 7/31/2024 is listed at the top before 9/7/2023 - so it's not considering the actual date and year but only the month....
jcarlson
It's also including a null value in the middle of the list... I would triple-check the sorting settings, it sounds like something's gone wrong there.
- Josh Carlson
Kendall County GIS
KaraUtter2
Exactly why I am putting in a ticket - the sorting settings are fine. The issue is in the widget configuration - this is definitely a developer issue.
jcarlson
Can you add other fields to the list to see if it's accidentally sorting by something else, or ignoring your settings and sorting by the ObjectID or something?
- Josh Carlson
Kendall County GIS
KirkKirchner1
I am seeing this same issue. Please have someone from Esri look into this
DanJiang
Hi @KaraUtter2 and @KirkKirchner1 ,
Could you share with us a sample data for testing? We did not reproduce the issue with in-house testing data. There could be something special with your date format.
Dan
