Showing multiple maps in experience builder
2017
09-16-2024 07:34 AM
ChesterGross
Hello,
I'm relatively new to experience builder and I want to show multiple maps in experience builder, preferably as filters that can be toggled and viewed together or individually. I've got about 6 individual maps that I want to show and I'm getting a bit lost as to how to go about it. I've been toying with the filter tool but because I can only select one basemap, the layers from other maps don't show up. I'm wondering how to go about doing this or even of experience builder is the right tool to use so any help on this would be really appreciated.
JeffreyThompson2
MVP Frequent Contributor
Experience Builder allows for adding multiple Map Widgets to a project. If you are on the most recent versions, you can create a Group Filter that allows for filtering multiple layers at once, including across multiple maps. Add a Filter Widget and use the carrot next to the New Filter Button to add a Group Filter.
GIS Developer
City of Arlington, Texas
ChesterGross
Yes, I've tried to display this data from a different  dataset/map onto the basemap  but nothing shows up or disappears. The data is from a different web map and now I'm a bit more confused as it may now be an issue with the conditional of the filter. Ideally when the filter is toggled the features that were true on the conditional appear on the basemap (ie. toggle if the year is 2022).
Ke_Xu
by Esri Regular Contributor
Hi ChesterGross,
Did you set the fields in Group Filter?
Ke
