Sending data to Survey123 Widget via Selection Tool (not clicking)
1012
12-07-2023 04:48 AM
tthomas9
I currently have a point feature set up in Experience Builder that sends data over to the Survey123 Widget via field/question connections. This functionality is awesome and works great when I click the point in the map.
However, I was wondering if there was a way to get the Survey123 fields to populate when a feature is selected via the search widget (no clicking on point in map required)?
I have the Actions set up on the search widget to where a feature is selected when searched via the address field (parcel lots) and it shows selected on the map but does not populate the Survey123 unless it is clicked. Does anybody have any fix for this/is this possible?
ElizabethGreaves
Hi Thomas,
In my experience using the Survey123 Widget in Experience Builder, it is necessary to click on the selected record in the map pane in order to trigger the refresh of Survey123 widget, pulling up the existing record associated with that feature. I have not found a way around this so, I'll be staying tuned for a possible solution too.
