Selection in Experience Builder not functioning correctly (BUG-000143500)
1799
08-12-2024 09:52 AM
RyanKelley_NA
I had put in a ticket for an issue with the selection tool in the map widget in Experience Builder in June of 2022.  When using the selection tool, only a certain number of features would be selected (these were coming from an ArcGIS Server) even if a large freehand selection was drawn.  For example, I may draw a giant polygon around a neighborhood to select all of the tree points, which there could be serveral hundred, but it would consistently only select up to 100 each time.  A bug was logged for this - BUG-000143500 however it still says this is an open bug that is under consideration even though I believe it was fixed.  Can anyone, specifically anyone from ESRI, confirm that this has been corrected?
Ke_Xu
by Esri Regular Contributor
Hi RyanKelley_NA,
This issue is already fixed. But I couldn't check the bug information in Esri Support.  https://support.esri.com/en-us/search?q=BUG-000143500&s=Relevance
Ke
abureaux
MVP Frequent Contributor
Do you have a link to the change log that references that being resolved?
Most likely, your only course of action would be to call Esri Tech Support and see if they can get a status update for you. But without anything more than that bug #, they would have a hard time locating additional details.
If all we have to go off is the bug #, which as you stated is still listed as "under consideration", then waiting is all that can be done unfortunately.
Ke_Xu
Hi RyanKelley_NA,
Ke
RyanKelley_NA
Thanks! I appreciate you sharing that information with me.
