Select Widget - "Set as Analysis input"
1542
07-29-2024 09:28 AM
Labels (2)
YS2388
Hello,
When using the Select widget's data action "Set as Analysis input", a new layer of the selected features gets created. Is there a way to disable this? These selection layers even get added to the side panel, and are named "Select", "Select 2", "Select 3" and so on, which is completely unnecessary and detrimental to my workflow. I have so far not found a solution for this. Any help would be much appreciated.
Regards,
YS
2 Solutions
Wei_Ying
@YS2388  thanks for your feedback.
What do you mean the side panel? The Layer list when you click analysis input or the Map Layer widget?
YS2388
Hello,
Apologies - I realized I was doing something incorrect. There are no added layers. Thanks for replying.
Wei_Ying
YS2388
Hello,
DougBrowning
MVP Esteemed Contributor
@Wei_Ying  We cannot get the Analysis widget to see selections at all either.   Many ways do not work.   https://community.esri.com/t5/arcgis-experience-builder-questions/select-widget-cannot-connect-to-an...
We have been stuck for months now.  thanks
