Select Widget - Layers off by default
661
02-10-2026 03:09 PM
ChivoGIS
I’m setting up the Select widget in ArcGIS Enterprise Experience Builder and need all selectable layers to be off by default. Right now, the widget seems to use the web map’s layer state, causing layers to toggle on automatically. Screenshot attached.
Is there a workaround to make the selectable layers start toggled off?
Thank you!
Tags (1)
ErikRose
Is there a reason you cannot simply leave the layers off by default in the source web map?
ChivoGIS
I am not in control of Web map, unfortunately
Faiez
@ChivoGIS  Have you tried this option?
ChivoGIS
Yes, this is how i have list of the available  layers.
