Search Widget Results Window Appears in Different Part of Screen When Closed
756
09-25-2024 01:19 PM
AB22
I have configured a search widget in Experience Builder in Enteprise. As far as I can tell, it is working properly in terms of finding the data and the associated 'zoom to' I set up. I am encountering a strange issue where the 'search results' window moves itself to the top left of the screen if you close the widget after a search.
Below is the results at first. No problems.
Then, when you close the widget, the window appears here (See below)
Seems like a bug to me but wanted to see if anyone else has seen this and if they got around it.
Thanks!
Laura
by MVP Regular Contributor
What version are you on?
AB22
Enterprise 11.1
Laura
Do you have 2 search widgets? Or did you configure it so the popup is in the right?
