Search Widget Actions that can pull other layers that intersect
1227
08-14-2025 10:01 AM
Zach-Williams
Hi there,
I have added a layer source to my search widget. It is a parcel layer. I also have other polygon layers that fall on top of those (layer is a overlay zoning district, i.e. central city overlay, scenic corridor overlay, historic preservation overlay, etc)
Is there a way that when you search a parcel and select it, that it can select those other polygon layers based on intersecting that other polygon layer? It sounds like the query widget, but if I have a query widget, I would want it to automatically a query to said other polygon layers that would intersect with the parcel I searched and selected, so users wouldn't have another step.
JeffreyThompson2
MVP Frequent Contributor
https://community.esri.com/t5/experience-builder-tips-and-tricks/zone-lookup-in-experience-builder-a...
This build can be used to find intersecting polygons from a Search Widget. They won't be selected, but they can be aggregated into a Feature Info Widget that can be flipped through and set to select the polygons.
GIS Developer
City of Arlington, Texas
DanielFox1
Hi @Zach-Williams
Can you try this workflow
1. Search Widget Configuration
• Add your parcel layer as a layer source in the Search Widget.
• Enable Record Selection Changes under Actions.
• Set the action to trigger a Query Widget or Filter Widget.
2. Query Widget Setup
• Configure the Query Widget to target your overlay layers.
• Use the spatial relationship setting: Intersects or Contains.
• Set the trigger source to be the Search Widget’s selected parcel.
3. Automate the Interaction
• In the Action Framework, link the Search Widget’s selection to the Query Widget:
• Trigger: Record Selection Changes
• Action: Query Data Records
• Data Source: Overlay layers
• Spatial Relationship: Intersects
• Optionally, configure the Query Widget to auto-run when triggered.
4. Display Results
• Use a List, Table, or Map Widget to show the results of the intersecting overlays.
• Connect these display widgets to the output of the Query Widget.
I hope this helps in some way.
