Report template for Experience builder
5612
01-15-2025 02:17 PM
DionisioBattad11
I have created an experience in Experience Builder. The experience uses a filter widget and when executed it zooms into the selected road feature and also filters the 2 tables in the table widget: the feature attribute table and the related inspection report table.
What I would like to do is create a customized report template that will contains the map and the 2 tables. The map and the tables are dynamic in that these change every time a new filter is applied.
I would like also to incorporate report tiles, logos, etc. in the template. Thank you for any help.
Below are examples of the filter output that I would like to be in the report:
ShengdiZhang
Hi @DionisioBattad11 ,
If you have access to ArcGIS Enterprise, you can publish a custom print service with reporting capabilities. For details, see https://www.esri.com/arcgis-blog/products/arcgis-enterprise/national-government/creating-a-custom-pr...
If you do not have access to ArcGIS Enterprise, you can use the Feature Report widget. One thing to note is that the current Feature Report widget only supports feature layers associated with ArcGIS Survey123 surveys. As far as I know, you can create a survey with an existing layer, then it is possible to use the Feature Report widget to generate reports. For details, see https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/feature-report-widget.htm
Please let me know if you have any questions.
Regards,
Shengdi
Danny_Thompson
If you have access to ArcGIS Enterprise, you can publish a custom print service with reporting capabilities. For details, see https://www.esri.com/arcgis-blog/products/arcgis-enterprise/national-government/creating-a-custom-p…
This is slightly confusing as the link launches straight into "In the February 2024 update of ArcGIS Online, the Experience Builder Print widget added the capability to utilize output data sources for generating dynamic report."
TimWestern
MVP Regular Contributor
As a fall back option, if you have a widget that collects the information, you can also build a view that would look like a report and open in a new tab.  The caveat there is, only a developer would be able to make changes to it unlike with the layouts and report templates in ArcGIS Pro.
getting print service and layouts setup has felt a challenge for some, where as generating in code and creating the report in a new browser tab for printing sometimes is far easier for a developer.  Given the time, I tend to still prefer trying to make the layouts available through a print service, but not every need, needs such to get the data they want in a format that is acceptable.  Something to keep in mind when making choices.
