Repeated Login Prompts in Experience Builder App with Embedded Dashboard
1501
08-23-2024 01:49 AM
IB3
Hello everyone,
I've developed an Experience Builder app that includes an embedded dashboard within a view in a section, which is accessible via a viewer navigator. Both the app and the dashboard are hosted on a single portal within a group, and the content is shared through a distributed collaboration between AGOL and Enterprise.
However, I'm encountering an issue where users are repeatedly prompted to enter their login credentials. Even after logging in, the prompt reappears when navigating to other pages within the app and then returning to the original section. The prompts don't appear consistently—it seems a bit random. Additionally, I sometimes get kicked out of the section when the login popup appears.
Does anyone have any suggestions on how to prevent these login prompts from occurring? Any help would be greatly appreciated!
JonathanMcD
If the data in your collab is set as references, rather than copies, then it'll prompt for a user to log into the appropriate platform to access that piece of data.
Ensure anything that's part of the experience, within the Portal group, is received as a copy.
IB3
Even if all the content is stored on my side, meaning AGOL, and I am also accessing the content via AGOL?
MapExplorer_27
I just had this issue, where I had a multiple dashboards embedded in experience builder, where some dashboards required a log in, and some were just fine. I found that it depends on which link you use for the embed. It seems that when I use the URL that the metadata provides shown below, it causes the issue for users to log in.
Whereas if you use the URL directly from the dashboard page, the login issue disappears. Hope this helps!
IB3
Thanks! Unfortunately, it didn't work for me.
ColmOKane
That worked as the url then had the organisation name at the beginning.
