Related Data Action working in Table Widget but not Feature Info Widget
1667
08-08-2024 07:48 AM
ThomasBucher
Hello,
I'm trying to leverage the new Related Data Data Action in a dashboard I'm putting together with Experience Builder. I have a feature service with two related tables for inspections and deficiencies logged during these inspections. I have a table that contains a paired-down version of the inspection results and when a user selects an item from the table, the full inspection result populates in a Feature Info widget.
Now, the problem I'm having is that when I use the Related Data action from the Table Widget, everything seems to work fine. (See picture below)
Related Data Launched from Table WidgetRelated Data Launched from Table Widget
But, when I try and use the same action from the Feature Info widget, the window appears but no information loads. (See picture)
Related Data Launched from Feature InfoRelated Data Launched from Feature Info
Does anyone know what could be stopping the Related Data from loading via Feature Info but not the Table Widget?
ShengdiZhang
Hi @ThomasBucher ,
To answer your question, you can hide the Related data on the Feature info widget by unchecking the action in the setting panel:
However, this action should work in the Feature info widget, can you share your app and data with me so I can take a look?
Regards,
Shengdi
MikhaylaB
I'm not seeing a Related Data box in the configuration panel for Feature Info, is it available for Enterprise/Portal? I'm on 11.3
ShengdiZhang
This feature will be available on Enterprise 11.4.
